vcLinearTarget
An object with properties to define necessary information to plan and execute a LIN motion. A kinematics behavior is required to execute a motion with this target type.
Module: vcRobotics2
Parent: vcMotionControllerTarget
| BaseName | String | RW | Gets or sets the name of the base frame to use. This frame must exist in the controller for the motion to succeed. |
| BlendingType | vcMotionBlendingType | RW | Gets or sets the desired blending type. Also see BlendingValue. |
| BlendingValue | Real | RW | Gets or sets the value that defines how early blending towards the next motion may start. Also see BlendingType. |
| ExternalDriverValues | list[tuple[Integer, Real]] | RW | Gets or sets the list of external driver values to reach at the end of the motion. The integer is the external driver's index in this controller. |
| InternalDriverValues | list[Real] | RW | Gets or sets the list of internal driver values to reach at the end of the motion.See moreThis property will be processed only if OriType is set to vcOrientationInterpolationMode.WRIST. This list is then expected to have as many items as there are internal drivers in the controller, even though only the wrist driver values are read. If the robot has configuration parameters, i.e. redundancy, that is to be interpolated, then the provided driver values are used as the target configuration. |
| IsExternalTcp | Boolean | RW | Gets or sets a boolean value that affects how Target is interpreted.See moreWhen set to true, the Base frame is used as the external/static tool and the Target is given in the Tool frame coordinates (tool-to-base). When set to false, the Target is given in the Base frame coordinates (base-to-tool). |
| MaxAngularAcceleration | Real | RW | Gets or sets the maximum angular acceleration. |
| MaxAngularDeceleration | Real | RW | Gets or sets the maximum angular deceleration. |
| MaxAngularVelocity | Real | RW | Gets or sets the maximum angular velocity. |
| MaxLinearAcceleration | Real | RW | Gets or sets the maximum linear acceleration. |
| MaxLinearDeceleration | Real | RW | Gets or sets the maximum linear deceleration. |
| MaxLinearVelocity | Real | RW | Gets or sets the maximum linear velocity. |
| MotionTime | Real | RW | Gets or sets a time for the motion in seconds. When > 0, the time to reach the target will be forced to this value, ignoring limits. |
| OriType | vcOrientationInterpolationMode | RW | Gets or sets the orientation interpolation mode to use. |
| Target | vcMatrix | RW | Gets or sets the target matrix which defines the final internal driver values at the target, along with base, tool, and external driver information. Also see TargetType and IsExternalTcp. |
| TargetType | vcLinearTargetType | RW | Gets or sets an enumeration value that affects how Target is processed. |
| ToolName | String | RW | Gets or sets the name of the tool frame to use. This frame must exist in the controller for the motion to succeed. |
